Has anyone successfully run bigadv on a dual E5649 system? I have one that is giving ECC errors even when I switch out the RAM. Not sure if I should reseat the CPUs and use some fresh thermal paste or what else could cause the known-good RAM to experience ECC errors. I went down to a single DIMM per CPU and only the second CPU's DIMM is complaining.
My dual X5650 system is getting around 130K PPD. The dual E5649 is claiming around 9K (frame time is 36:13). I imagine part of the problem is memory bandwidth since I went down to a single DIMM.
When I had this same system as my VMware vCenter server running 2008, it would reboot every couple of days. It doesn't reboot with Linux, but it's not behaving properly either.
