Dual DVI Video Card
fibroptikl
I'm looking for a video card, that has two native DVI ports - I don't want to use an adapter.
No gaming will be done, but if I want to fire up a game - I'd like to be able to.
No Matrox.
Anyone?
I did some searching, and apparently nVidia has some.
ATI has some as well; only they are on the FireGL, and I'm not into spending more than $200, $150 if I can help it.
not gonna happen .. only card I've seen with dual dvi is the 6800 and that's not even out yet .. ati's next gen may have it, but don't think so ..
the Nvidia card is gonna run you probably $500 .. unless when they release their low end cards .. they may have dual dvi too ..
nice. that must be a fairly new model; a month or two ago nobody was able to point out budget dual-DVI cards.
Of course, when you're buying a pair of DVI-capable displays, $200 for a decent card isn't really a big deal.
Originally posted by _Sin_
http://www.newegg.com/app/ViewProductDesc.asp?description=14-128-186&depa=0
wow, you guys must be behind the times :p
as much as I hate Nvidias fx line(current) thats probably going to be your best bet right now.
edit- here is an even cheaper card, though i really have a hard time reccomending this, why cant you just use an adapter and get a GOOD card? like a 9500-9800 in your price range of ~150 ?:p
http://www.newegg.com/app/ViewProductDesc.asp?description=14-121-151&depa=0
Cause I don't want color differences; I'm just trying to get the same picture quality on both.
Get the 5700U, not the 5700. Only $2 more:
http://www.newegg.com/app/ViewProductDesc.asp?description=14-128-188&depa=0
