Dual-DVI 6800 cards?
jlee1
I'm looking for a 6800NU because my pricerange is around 280-330. I really want two dvi ports because I plan on running two 17" lcds (for coding sessions). I have only seen one, an XFX on newegg, and one of the user reviews says the clock is 325 and not 400 as specified, so I wasn't sure if that one was good.
Some advice would be most appreciated.
Thanks.
im sorry i cannot provide a link but i am positive there is a 6800NU two-dvi port card out there
EDIT: sorry misread a little i'd go for it and maybe try a bit of overclocking, if not there not too bad of speeds
How about getting a regular 1dvi 1vga card, and then an extra pci card that has a dvi out for the second lcd? I don't need both to be accelerated, since I'd only use 1 screen when gaming. Will this lead to weird color differences between the monitors, assuming both monitors are the identical model?
Since you're using DVI, no. There will not be color differences unless the monitors themselves have color differences.
