Dual Display Question!
JadedMaple
Hey, My folks are buying me a new dell with a $2600CAD budget.
I can get Dual 17" CRTs under this price cap. But the maximum resolution for the 6800 is 1920 x 1200 what does this mean on two monitors?
Nothing unless you are getting 2 23" widescreen monitors...
How much for each monitor? What specs in the system? If you build the system yourself you might be able to get 19" crts or maybe lcds.
I am running 2 19" LCD's at 1280x1024 using a x600PCI-e
