Dual display question (clone desktop)
Forgiven
I am trying to output the same output on two monitors. I DON'T want to extend my desktop. What video card can I use to achieve this? I used to be able to do it with my 8500 but my 9800pro won't. I also don't know if it is something the catalyst boys took out.
In any event...if you are or can do this function...post your card and driver so I can get it...cheaper does mean better..thanks
Steve
I have the newest Catalyst drivers, I can clone. Just go into Display properties, and click on your second monitor. Below that you should be able to check the box that says 'Extend my windows desktop onto this monitor' and it should be a-ok.
