Dual Display Question (backgrounds)
the X
i just got my 2005FPW to go alongside my NEC FE991SB and i cant figure out how to get different backgrounds on each one... when i change the background on either one it changes it for both... my only guess is that maybe it takes software to do this? please help.
you can also do it by hand.
I used that procedure and it was easy, the first step was to press the "PrintScr" key and open it on Paint. Now you have an image with the correct size, and you only have to paste desired backgrounds in that image.
thanks guys... the Ultramon works goood! but it expires in 30 days :(
If you have an nVidia video card you can use nView to manage your desktops. It has a lot of different features too, def. something to try if you have dual monitors. ATI probably has something similar.
im using a XFX 7800GT ... I tried using the Nview properties etc but i couldnt find anything for wallpaper
