Dual Core Voltage (Vcore1 / Vcore2)
only one is right. the entire cpu is on the same voltage plane, meaning that it's all fed by the same voltage regulator.. so the two cores HAVE to be running at the same voltage :p
try a different program, or figure out which one is right and disable the other
