Dual Core Voltage Question
Presto88
Do any of you guys know if its at all posible to raise the voltage of one core of the other?
The voltage is set by the MB... unless your MB had dual power lines I'd have to imagine you get a single option only.... interesting idea tho... any reason for wanting to do this?
pretty much because one of my cores gives out while the other is still cruising when priming up around 2600 mhz.
Also I thought I saw a guy over at extreme systems that I thought he said he had dif voltages on the two cores.
