Although S939 boards should support dual cores with a BIOS update, we have yet to find one that has worked correctly. Currently, we have a Tyan S4882 rev2 running with 4x Opteron 875 (8 cores total). Everything works fine but the SATA controller...xonik said:CPU availability of the Athlon 64 X2 and Pentium D are currently limited to prototypes and engineering samples, if I'm not mistaken. I have yet to hear of a confirmed receipt of either CPU by a consumer at this point.
As for motherboard availability, here's what's up. Every Socket 939 board, to my knowledge, supports the Athlon 64 X2 out of the box or with a BIOS flash. Check with the manufacturer to see which scenario applies. As for the Pentium D, there is limited support by a few Socket 775 boards. You'll have to check with the manufacturer to see if the Pentium D is supported.
