Sean22190 said:yeah, because they are still the same socket...
Igg said:if anything, the heat will be spread out more evenly now over the protective pad so our existing blocks would cool even better
Devilpup said:chip makers know they are producing a lot of heat already and they're not completely stupid. if it caused a significant increase in heat production i don't think they would do it, because the norm air-cooled units are already getting so loud it's becoming an issue
MikeyB said:I've been wondering about this. If the surface area of the core is now greater might some of the directed flow blocks need to be retooled / modified for optimal performance? I think the worst that could happen would be slightly poorer performance, not total incompatibility with current blocks.
Etherneal said:Why is it so much more expensive? Almost 100% more, but its considered the best?
If you guys suggest it I'll get it, and that price tag is really appealing too.
Top Nurse said:In case you don't notice they are running a Pentium 4 EE 3.2 at 3.68 Ghz using an Aquastream pump and some Airplex Evo radiators. Hmmm....so much for low flow not kicking it![]()
Cathar said:Yes - it's almost matching stock air-cooling in terms of overclocking. Rocking [H]ardcore!
Sig'd for truthCathar said:Yes - it's almost matching stock air-cooling in terms of overclocking. Rocking [H]ardcore!
