dual core + cool N quiet
sdadept
How many of you use cool N quiet with your dual core chips? I'd like to build a machine that might idle quite a bit between bursts of heavy use and I'd like the cool N quiet to work.
what's been your experience using it? does it make the machine sluggish even in heavy use? does it kick in correctly? what mboard do you use with it?
any informaiton would be greatly appreciated.
The thing is, I think many people overclock thus they cannot use C'N'Q while overclocking. So I dont think that many people actually use it but...
Id definitely use it if youre gonna run at stock though. Why not heh. In terms of use, I dont have much experience using it so someone else can probably answer those other questions.
yea, I'm going to run this machine at stock because stability (especially long term stability) is key for the machine I need.
Why not buy a quality heatsink, slap on a low speed fan, and forget the buggy C&Q altogether?
Is there something from preventing them from doing it or is it just not recommended?
and do dual core Opterons have cnq enabled in regular motherboards?
Yes, because think about it. When youre overclocking, chances are youre using the lowest vcore that makes it stable and the highest speed. When CnQ kicks in, it lowers the voltage itself which is going to make the overclock unstable and probably crash the computer.
And it is somewhat buggy anyways, most people dont use it. There really isnt a need. Get a good heatsink and fan and youre set.
I use this program.
http://cpu.rightmark.org/products/rmclock.shtml
It puts an icon in the system tray, allowing you to chose what performace level. You get to choose what Voltage and what multiplier to use for each level of performance. I use it on minimal performance in windows, Keeps my 3000+ at 1200mhz, 1.1v. When gaming i just right click on it and whack it up to maximum speed, 2250 mhz at 1.5v. Easy peasy.
Never had a single lock up because of it.
I run CNQ and have a mild overclock on my 4400 (2.4) and it's not buggy at all
buggy for you cause you have a dfi + opteron ;)
i've never had a problem with cool & quiet in any board with an officially supported cpu, either at stock speeds, or overclocked.
a tip though, use RMclock, not the amd drivers. you have a lot more flexibility over what happens :cool:
I use power now on a dual 252 K8WE box and the rightmark clock util on a 170 a8n-sli box.
The tyan works flawlessly, however there is overhead related to the switching. If a task is not constant 100% load and throtles up and down a good bit then the overhead causes it to be a few % slower in iterative computational loads than with the power management disabled.
The a8n board does not seem to have a proper power state transition table in it's bios, so I leave the feature disabled and use the rightmark utility and created my own p-states. This box does typical multi tasking daily driver type stuff, and the switching is completely transparent from an end user standpoint. However, I am sure the same overhead applies.
Additionally I have a 146 in a DFI expert that is heavily OCed on phase change that I had not ever tried the cool n' quiet or the rightmark CPU clock utility. I would guess that it would work if you used the special % overvolt feature instead of manually setting the VIDs. This would allow software control of the VIDs without messing up the OC. You could also generate a custom table and verify stability at each FID setting to ensure it worked as intended.
