Dual Core and Gaming (BF2 mostly) - Poll
Dual or Single Core for Gaming (mostly BF2)
  • AMD Dual Core all the way!
    Votes: 87 75.0%
  • AMD Single Core FX-57
    Votes: 16 13.8%
  • After I experienced all those troubles with Dual Core I should of go with Single Core (FX-57)
    Votes: 5 4.3%
  • After I had all those troubles I would go with Dual Core anyway
    Votes: 8 6.9%
  • Total voters
    116
Bona Fide said:
That's the patch, not us. EA better realize or they'll lose a helluva lot of customers. Anyway, I stopped playing BF2 because of Oblivion :p
LOL as soon as I get oblivion I think I'll lose about 2 years of my life...
and I'm not formating, I did just a couple weeks ago...
One thing you can do is delete you bf2 folder in your my docs, and then delete everything in your temp folder...
I did that and it seems to be working fine now... Still a few gittery frames but I have no clue why that is... might be my 7800 draining all of my pws.. :) dunno dont care right now, too poor to worry about it...
I've had no problems with my X2 3800+ and BF2, Far Cry, COD2, HL2, or Wolf:ET. I have the AMD Dual Core CPU driver installed but not the hot fix.
Personally I think your concern should be with your GPU, not your CPU for a gaming rig. The difference between an FX-57 and an X2 4800+ in framerates in any given game is going to be neglible at best... and most X2 3800+ chips are capable of 4800+ clock speeds, even with stock cooling.
I chose the dual core chip for the benefits it would give me outside of gaming AND while gaming. It's nice to be able to ALT+TAB back and forth between heavy appz and a game I'm playing with little or no delay. :)
Well. I run Win x64 with my 4200x2. My specs are in my Sig.
I've sent EA a letter about 7 times, and they give me the same stupid reply over and over again. I know how to set affinity, I know how to update my drivers, I know how to manage a computer. Since the last patch they put out, BF:2 crashed out completely with no warning. To humor myself I reinstalled it, put the patch back on, and then, I started getting No Packet Flow errors.
ok ok Something new and interesting. I check my firewall and everything that could be screwing with connection. Nothing is flawed, every other game runs like a model T when they were the shiz.
I'm planning on reinstalling without the patch. See if something will change. But, I did a fresh format no longer then 3 weeks ago. Ran the game just like those Model T's and never once had a problem up until the that 300mb pos thing they call a patch.
I mean, is anyone else having this problem or is it just me ?
I didnt ask for a stupid opinion, as I've stated already. I've never had a problem with Win64 running programs.
*sigh* How is that a stupid opinion?
From the 1.21 Patch Readme file:
ftp://largedownloads.ea.com/pub/patches/readme/readme_en_us.txt
System Requirements
- Operating System
Windows XP (32 Bit Version)
Also..
BATTLEFIELD 2: SPECIAL FORCES AND THE PATCH
- It is very important to remember that the Special Forces executable is an earlier
version of the game. If you have purchased Battlefield 2: Special Forces after
you have installed the patch, you will need to reinstall patch 1.2 after
installing Special Forces.
You mentioned it being a 300MB patch, it's not unless you're trying to run it on a vanilla BF2 install. The incremental patch (from 1.2) is only 13MB.
Now a high power single core is better for just gaming. That may change in the near future.
Even if a dual core is rated at the same speed of the single core, with the same amount of cache?
AMD64 4000+ - 2.4GHz w/1MB cache.
AMD64 X2 4800+ - 2.4GHz w1MB cache.
Your saying the 4000+ would be better for Pure Gaming?
:shrug: ha
