I was wondering if I would notice a huge difference between having a Dual Channel Kit of 2x256 Mb PC 3200/3500 versus a Dual Channel Kit of 2x512Mb PC 3200/3500. I am thinking about OCZ ram since I hear that with Corsair you basically pay for the brand name. I was told that they are pretty much the same in quality, tested in the same way and that the difference really is the name, hence the price difference.
Is there any benefits or cons of having more or less memory? (My system is mainly used for gaming - there are a serveral things that run in the background like virus scanner, firewall and such). I don't usually play with super high AA & AF settings (bc of my Vcard, which Im fairly happy with at the moment), but I usually like to play with high resolution and usually use high settings in a game.
I'm also starting to become interested in overclocking, so I'm open to CPU cooling suggestions for overclocking. I would rather try not to spend an arm and a leg for it, but if that is the case then I may reconsider it. Thanks in advance!
Cheers!
Cheers!
