Hello,
This is a brand new system specs are listed below in my sig. When I run one stick of ram (1gig)through prime95 over 6 hours its stable as a rock no lockups, both sticks work the same way, however when I combine them as a pair for dual channel(2gigs) Prime95, 3dmark 03 both report errors and or lock up. I have tried the ram in all 4 slots for dual channel same issues, I have tried the single ram in all the spots and they seem to work fine, but once they are paired up I get errors. So my question is what might be the issue the ram or the motherboard? I will need to RMA and would like to be as accurate as possible. Well I tried the ram off my main system in Dual Channel and it seems to be working fine. I will do allot more testing yet but so far the test has not failed. I wonder if I should get another type of ram?
