So, I just got done assembling everything. I have a few problems I have been trying to figure out. First of all, and the most annoying thing - is for some reason there are black bars on top/bottom and left/right sides of my screen. I have installed all drivers from the CD. Resolution is set to 1920x1080. I AM using onboard gfx card (HD 3300) and the mobo says it DOES support 1080p. What could be the problem? When I go one step down: 1680x1050 it is full screen as it should be.
Secondly, I do not think I have the dual channel installed correctly. I just opened up Everest and under the memory tab it says: "Bus Type Unganged Dual DDR3 SDRAM" The mobo manual is not very clear on how to install dual channel. I have them installed in both orange DIMMS.
Specs:
CPU: AMD Phenom II X4 955 Black Edition Deneb currently @ stock
COOLER: Corsair H50
MOBO: ASUS M4A78T-E AM3 AMD 790GX
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) DDR3 DDR3 1600
GPU: onboard HD 3300
Specs:
COOLER: Corsair H50
