dual channel dilemma
[H]otspringtamago
the new computer my parents got me is perfect, but with one hitch: the memory.
it has 512mb of ram, but instead of 2x256, it's one stick of 512! this is especially concerning because it's a p4.
my question is that if i get another stick of 512, will the dual channel work ok, and will there be a speed increase? because i know that they won't be twin pairs of modules.
answers/ help with my dilemma are greatly appreciated,
thanks in advance!
They should be fine do you know what motherboard it is? I use 2x512 mb sticks that are same brand but different speeds and grades from kingston and they run dual channel fine. My ram is Kingston Hyperx and kingston valueram., both are DDR333 running at DDR400 in dual channel no problems. So I it might work for you it might not depends on the ram and motherboard.
all i know is that the chipset is the 865 from intel, but it is in a gateway comp (the parental units wanted to make sure i didn't mess anything up since it was their money that purchased the system).
865 is DC yes. Usually it should be okay, I'd just stick with the same brand. But even if it's not, it *SHOULD* be okay, they're not as picky as with the nForce2 systems...
thanks for the input guys! i really appreciate it. :)
as soon as i scratch up enough money then i'll get me another stick of 512... or maybe since there's three open slots, i'll get 3 sticks of 512 and have a monstrous 2gb of ram :eek:
mmmm.... ram.....
thanks again!
