Dual channel and its purpose
dod_gamer
Bad Trader
Ok, I have 2 sticks of CMX512-2700 c2 and a FICAU13 and I am running dual channel according to CPU-Z and havent noticed much difference, although i have played games or anything, but here is my question:
Since i have 1gb total of memory, does dual channel run like RAID and actually is 512 mb, or is it actually 1gb. Or does it split a file and load it to both sticks for faster access. I do not understand the concept of dual channel, so will some one PLEASE enlighten me, give me a crash course or something, thanks!
this one's easy to answer,
http://hardforum.com/showthread.php?s=&threadid=707289
(it's a sticky at the top of the page here...) anyways, skim down through that and look for the heading "DDR Dual Channel" or something like that. search the first page, it's on there, with everything and more then you need to know. basically, it just creates more bandwidth.
doesn't eat up half your memory or anything... in my opinion, 95% of the cases it won't produce any noticable differences... other then that the person that just upgraded to dual channel now has twice as much memory :p
DC on AMD setups only increases performance ~3-5%, so the bigger increase in speed is from the additional RAM.
You've just managed to offend all P4 users with 865 or 875 chipset boards.
1GB of RAM is a big plus in todays systems. I guarantee the majority will notice a huge difference if they do very much on their system.
As far as dual channel goes the reason you dont see alot of real world difference is because most applications and all games dont use very much bandwidth. Dual Channel doesn't double the load capacity of the RAM, it theoretically doubles the bandwidth allocated. So instead of 3.2GB/s of bandwidth you have around 6.4GB/s of bandwidth. That extra bandwidth is pretty useless in most areas and then in other areas like with encodeing and rendering and heavy applications it can be of some use. But for games dont expect to notice a difference. Games respond to tighter timings. Thats why i think PC4000 with its lax timings was the biggest joke on the computer gaming society to date.
And if your setup is an Athlon XP board then dont expect to see any differenece in any area :p .
