Dual Chamber Case?
_mike_
Are there any other dual-chamber case designs, other than the YY? Maybe something in aluminum?
I was hoping for something smaller, more cubish, since their is no need for a 19" tall case when the drives are "next door". Thanks for the suggestion tho
I've got a YY sitting in my basement right now that I was planning on modding. After I got everything mounted inside of it I realized I just hated the case. Now it's been consined to the graveyard of expensive cases collecting dust alongside the Supermicro SC-750a (which is a wonderful case if you need a boat anchor).
I'd just try to find two inexpensive aluminum cases (there's a couple companies making Lian-Li knock-offs) and rivet them together.
Otherwise, there's alwasy the Mountain Mods UFO Cubes which are gorgeous cases but expensive as heck.
I've seen the UFO cubes, and if I go that route, I'll just build one, those aren't worth $300, nor do I like the style, 3 windows, 184 blowholes, etc.
I would like to bolt two together, but thats too large for my table, with a 19" CRT, 17" CRT, and 12" CRT, plus laptop, and a few keyboards.
Guess I need to start drawing up some plans?
