Ive installed Vista Beta 2 and now Pre-RC1 and I am still unable to dual-boot with XP on a separate physical hard drive. The Vista OS menu has "previous OS", when I select that I get an error stating that XP is unable to load. Something like NTLDR missing and I even saw Winload.exe problem. Has anyone else been able to successfully boot Vista and XP properly? I ended up doing a "fixboot" on my XP install and that seemed to fix things. Not the first time I have done this either. But now to load Vista Pre-RC1 I have to unplug my first hard drive which has XP on it so Vista will load.
Here is how I installed Vista. I booted off the DVD that I burned from the ISO download and then selected for Vista to be installed on my 3rd drive. My XP drive was still plugged in at the time. All 3 drives said primary beside them. Did I do something wrong at that point?
Thanks!
Thanks!
