TheDarkTao
- Feb 5, 2005
Hey,
I have been running windows xp64 (trial/beta). I just got a new motherboard, so I reinstalled windows (it did work with the new board but I wanted to be safe). Problem was that it had some sort of conflict with the ethernet driver from nvidia, so I had to install a second copy of windows in another partition and DL the driver, then reinstall it to the C drive. Well, it got all buggy, so I completely reinstalled windows to the C drive.
Problem is that after I uninstalled windows to the second partition (I made it on my D drive) it still shows both OSes on a reboot. I deleted the windows files, and formated the D drive. But it still shows both OSs as bootable. If I try and boot from the second OS (the one I deleted) it obviously gives an error message and then reboots. The first one works fine though. I just want to uninstall the second one completely. Every time I boot up that stupid chose OS screen comes on. Any way to fix this?
Any help is much apreciated. Thanks.
