I tihnk i do need to edit the boot.ini file but where can i learn how to do this?Ice Czar said:well first carefully read through this as a troubleshooter
http://hardforum.com/showthread.php?t=766702
and then describe how the two installs came to be, and the physical config
if they each have a system partition written to them we can make either or both crosss boot to the other by editing the boot.ini(s), and or changing the boot order in the BIOS
Thanx alot that worked also just so you know the second partition descriptor is 1 not 2 (partition is always 1 if you only have one partition on the drive)Ice Czar said:[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Whatever you like" /fastdetect
multi(0)disk(1)rdisk(0)partition(2)\WINNT="a different descriptor" /fastdetect
and test it I think the 2nd partition descriptor changes, but it might be 1 as well
as long as you leave the first alone youll always be able to boot into it
