Dual Bios Question and flashing.
hank123
With dual Bios If I flash and it goes bad does it go back to a older bios?
there are two chips, if something goes wrong to the primary chip the other one kicks into action. You'll have the option to reflash the primary chip
ok cool so if I mod a bios and its bad I should be good right? if thats the case I will just put a few bios on flash, 3 1/2 and cd.
Thanks!
