Ok, this should be easy to figure out but, I'm tired of failing at it so I am seeking some assistance.
The old rig & setup:
The last motherboard I had was an Asus A8N-SLi. I used the SPDIF onboard audio (ALC850) and connected it to my Onkyo HTR520. In addition to this, I would hook my headphones to one of the speaker ports that was also on the onboard audio. Both of these connections were on the back of the motherboard where the I/O plate is. Audio played through both the Onkyo HTR520 and the headphones simultaneously. If I needed to use my headphones, I just plugged them in and I got sound. If I wanted to have 5.1 surround sound, I turned the Onkyo HTR520 on and I had sound. If I wanted to have the same audio playback through both the headphones and the Onkyo HTR520 simultaneously I could. It worked without any hassle at all and there was never a front audio I/O connected. In case it matters (and I have a hunch it does) I was on XP Pro 32 at the time and, the SPDIF was set as the default audio..
That brings me to my current problem. I am trying to use the same audio setup as before but, on a new system.
The new rig & setup:
I am now using a Biostar TA990FXE with W7 Pro 64 and, I have the SPDIF onboard audio (ALC892) connected to my Onkyo HTR520. In addition to this, I hook my headphones to one of the speaker ports that is also on the onboard audio. Both of these connections are on the back of the motherboard where the I/O plate is.
The Problem:
I can only get sound out of the headphones or out of the Onkyo HTR520. I can not get the same audio playback out of both of them simultaneously. I have looked through Google, did a quick look-about here, and dug through both the Realtek software as well as W7 Pro 64 and I am just stumped. It either has to be a setting, a difference between XP Pro 32 vs W7 Pro 64, or a difference between the ALC850 (A8N-SLi) vs the ALC892 (TA990FXE).
What I have tried:
I have hooked the headphones to every last 3.5mm jack on the motherboard except the mic in. This has not resolved my problem.
I have looked through the W7 Pro 64 sound settings and the Realtek settings and made various changes. This has not resolved my problem.
I went into the Device Manager and disabled the generic HD Audio device. This resulted in removing the Realtek HD from the Device Manager and no sound after a reboot. This has not resolved my problem and I had to enable the generic HD Audio device.
I have tried reinstalling the Realtek driver on the CD that came with the TA990FXE. This has not resolved my problem.
What I have not tried:
The driver is up to date according to the Biostar site. There is a newer generic driver from Realtek that I have downloaded but, I have not installed it yet. I don't feel this is a driver issue otherwise it would be all over Google. To be fair though, this is probably not something a lot of people try to accomplish.
I have not tried using HDMI audio as the Onkyo HTR520 does not have any HDMI connections on it and thus it is not an option.
I have not tried using the headphones plugged into an HD front audio panel because I do not have one. I have an AC97 front audio panel from a random PC lying about but, the TA990FXE can only use a HD front audio panel. I don't think this would solve the problem though as it will either mute the rear onboard audio or, it would play back a separate audio stream simultaneously with the rear onboard audio. That's assuming I am understand their wording correctly. I take it to mean I could output the audio from a game through the rear onboard audio to the Onkyo HTR520 and then I could output the audio from something like Vent/Raidcall/Skype to the HD front audio panel to a headset/mic. If I am incorrect about this please let me know because, at some point I will need to find a way to playback game audio through only the SPDIF while audio from something like Vent/Raidcall/Skype is playing though only a headset/mic. (e.g. I will only hear WoW through the SPDIF audio and I will only hear Vent through the headphones but, both of these need to occur simultaneously.)
What I am looking for:
I want to be able to either plug a set of headphones in or leave them plugged in to the rear onboard audio and be able to get sound from both the headphones and the Onkyo HTR520 through the rear onboard audio simultaneously. (e.g. If I am listening to a song through the SPDIF, I want to be able to hear the same playback through the headphones simultaneously). This was accomplished without any effort at all on my old rig and I am desperately seeking a way to make it happen on this new rig.
For clarification:
If I am receiving audio into the headphones connected to the rear onboard audio and I unplug them, the audio will start transmitting through the SPDIF and playing out of the Onkyo HTR520. If I have audio playing through the Onkyo HTR520 via the SPDIF and I plug in the headphones to the rear onboard audio, the audio will start playing through the headphones. I want to have the same audio playing through both the SPDIF and an analog connection on the rear onboard audio simultaneously without adding any other hardware.
Is this possible or am I batshit crazy? BTW, feel free to take a shot/drink every time you see the word simultaneously in this post. You'll be drunk off your ass in no time flat.
The Problem:
What I have tried:
For clarification:
