Dual Audio Out Lines
Is there a way to use my audigy 2 zs for game sounds and my onboard nforce4 audio for ventrilo, winamp, etc? Basically I want to use my logitech z5300s for my audigy and hook my headset up to the onbord, and switch between the two. How would I go about this?
You'd set your Audigy as the default sound card in control panel and then manual change the output device in each application you don't want to use on the audigy.
Depends on what you're using to play them. It's player specific where as DivX is just an encoding/compression algorithm.
So if you're using the divx player... look in there.
