Either of the above works (assuming you're not running in an SLI/Crossfire arrangement, which ties up two whole cards for one display). XP should support a whole hell of a lot more than three, to my knowledge the real limit is how many adapters you can cram onto a motherboard (I'm sure you need specialized software eventually...Multimon does nice things if your display count gets too high, and there are other such programs around).
It helps if the cards are the same brand, since different video drivers don't usually live together peacefully.
That would depend mostly on the resolution of the displays you want to drive, and how tolerant you are of slow screen refreshes. You almost definately don't need some crazy card with 300-1000 MB of onboard memory...128 or 256 would be effective, cards with only 32-64 or ones that share your system memory are probably worth avoiding if you can.
Alright- going with two single-output cards, how important is it they be of the same make?
Are there really all that terribly many problems with different cards?
You're unlikely to be able to use ATI and nVidia drivers together, however the drivers built into Windows should give any video card basic functionality. The available resolutions will probably be more limited.
You might want to keep in mind that fewer cards means a less complex system, and assuming each card has an equal heat output...
