The Internal
- Nov 14, 2004
Hey all,
I started playing Skyrim again recently and added the SoSENB to it. I play skyrim on my 2560x1440 27" Catleap Yamakasi 2703. I have an old 24" 1920x1200 dell in portrait mode also hooked up / powered on. In NVIDIA control panel, it's set to "maximize 3d performance" and SLI is listed as enabled.
I'm a little confused why Skyrim is averaging a mere 24 FPS. I have every setting maxxed, as well as the SoSENB enabled. The FPS is holding pretty steadily at 24 FPS, mind you, I'm just a bit annoyed that it's not higher.
Is there something I need to adjust in a .ini file or something? Is this "normal" for a 2-way SLI rig for this game? Benches I've seen (at a mere 4x AA) suggest 80+ FPS.
Relevant specs:
Core i5 3570k - OC at 4.4GHz
dual Gigabyte Geforce 670 GTX cards in 2-way SLI (model GV-N670OC-2GD)
16 GB DDR3
Samsung 830 SSD 256 GB programs drive
Windows 8 Pro
NVIDIA driver ver. 310.70
Relevant specs:
16 GB DDR3
Windows 8 Pro
