Dual 5030 Dempsey (Socket 771) good for normal usage?
westrock2000
Its about time to upgrade, and I'm thinking of some options.
I was looking these newish Socket 771 Dempsey chips. 2.66 Ghz, 64-bit dual core with hyper-threading, so that would be like 8 processors if I ran two of them?
It would be about $480 for a motherboard, and then $150x2 for the processors. Then 1Gb of memory (at first) is $147.
This would be for normal usage, like games, handeling multimedia....no server work. I'm OK with the processor count being less useful in WindowsXP if it Vista is going to take advantage of multi-processor setups.
So thats $920 for motherboard, 2 CPU's and memory. Am I making it way to complicated and a traditional single processor would be better for what I want....or would this setup last a good long time? The chips are awsome price I think...its the damn mobo's that are expensive. Theres cheaper mobo's for the Opterons and big Xeon's, but the chips themselves are like $300 a pop, so the Dempsey is still cheaper overall.
I'd recommend going with woodcrest if you can. Although you can always upgrade your processors later down the line, if you do go with dempsey though. You'll want to go with four sticks of ram eventually to fill all four channels, FB-Dimms support 6 channels but the intel 5000 series chipset only supports 4. Personnally I like the Tyan Tempest i5000xl board in terms of bang for the buck, you definitely want a 5000x chipset, as it's the workstation chipset. I just like a board with 2 pci-e x16 slots so I can drive three monitors with good video cards instead of resorting to a PCI card. Those 5030s sure are getting cheap, remember, you have to go 5060 before you get the 1066 fsb.
You will need to buy 2 sticks of FB-DIMMs. It won't boot with only 1 (According to Intel docs).
And don't, for the love of god, buy the 667FSB processors. Get the 1066... you won't regret it.
Well hell, I just checked my email today and Apple is now selling Dual Woodcrest Mac Pro's for $2500. I may as well just do that instead :cool:
