Dual 4870 or 4870x2
WozniakMac
Just built a new rig with a Q9450 and a DFI LP Jr TR2S. I am trying to figure out which way I should go. I have the option of going Dual 512MB 4870 or getting a single 4870x2. It's going in a mini P180. Thanks.
Just looking for the best between the two. I thought the difference in price wasn't that big of a deal. I am playing at 1920x1200.
Then you might want to think about saving some cash and going with a single 4870. Or maybe 1GB 4870.
because a single 4870 1mb is capable to play any games with good frame rates at that resolution, of course you can turn everything on high but it won't a killer like the X2.
4870x2
Pros: eats every games at high setting, fast
Cons: cost, min 24", heat, some games may not scale good with dual GPU, require good PSU
4870 1mb
Pros: fast single GPU, cheaper than x2
Cons: cost about $50 more than 512mb version
dual 4870 512mb
Pros: faster than single 1mb version, capable to play higher resolutions, cheaper than X2, if you shop around you can pick up a pair for less than a X2
Cons: cost more than a single 1mb version, heat, some games may not scale good with crossfire, require good PSU
Well, it's all depend on what type of game and resolution that you want to play, of course the budget too.
If you're hardcore gamer then the X2 is the best choice for you
If you're casual gamer on budget then the 1mb version
If you want some where in between then 2 x 512mb crossfire.
Just get the X2, it uses less power than dual HD4870 and it is fast, perfect for 1920x1200 with AA.
