I plan on using a MSI boardMarduk said:What board do you plan on using? That'll be your determining factor.
MOST Opteron boards don't support overclocking. Somehow eaking out that extra 5% performance isn't high on most Opteron users' priority list...something about "stability" and "robustness" or some other gibberish
at K8WE.com, other people using my board have said they'd get about a 10% OC...but it was through software like nTune. There is nothing in the BIOS that allows a hardware OC on the K8WE.
Marduk said:1.8ghz.
or are you referring to a more "relative" answer?
I'd -guess- comparable to a 3000+ Athlon64 on a per-CPU basis. my 246's give me about the same performance as my 3500+ did in benchmarks...although the system runs much more smoothly than it did w/ the single 3500+
SLiLOVER said:So I've heard LV Xeons overclock highly ,are Opteron 242's worth the price?
oops...you're right. For some reason I was thinking my 246's were 2.2ghz. (even though I know better...oh well)Moog said:242s are 1.6 ghz. 244 = 1.8ghz.
Marduk said:I think I paid about $430 for the non-SCSI model. Newegg should have it...
if you're not worried about SLI...but with your name I doubt that....Asus and supposively MSI were supposed to have dual Opterons based off the NF4 2200.
the K8WE has the 2200 and 2050 chipsets, which allows 2 16x PCI-e lanes, 2 Gigabit, etc.
Out of curiosity, why aren't you looking at an Athlon 64 X2?
Opterons and Xeons have the additional cost of ECC/Registered RAM...whereas the Athlon X2 can use standard DDR.
I never intended to go dual Opteron; I always planned on an X2...until the AMD Tech Tour's Server bundle changed that plan..
Marduk said:I do, I do.
I just wish I'd planned for dual Opterons rather than a dual core Athlon 64. I'd have made a few changes to it. 850W SSI PSU, smaller heatsinks(or at least ones that had a different airflow path).
I'll go dual core in the future...probably a year or 2 from now...
Marduk said:I basically need to figure out what's going on with my life and my girlfriend before I go dual core.
If she goes into Graphic Arts and needs a rendering box...that means I need to keep the dual Opterons and build her a rendering system.
If she doesn't...then I could get rid of them to foot some of the bill on the dualcores.
when I do go dual core, though, I'll likely be buying an additional 4gb of RAM to fill my slots. And I really should look into a custon 850W PC Power & Cooling. Now that I'm looking at almost $3k for the upgrade...I think I might be better off holding off until...oh who'm I kidding? Christmas-ish most likely
*edit*
Actually....I really do need to start saving for her engagement ring....I guess I'll be "stuck" on 246's for a while longer...
Marduk said:I'd personally take a dual Opteron over a dual Xeon. They're just insanely powerful.
the 1.6LV Xeons, regardless of how high everyone else says they go, are usually a gamble. Sometimes you get 3.2ghz, sometimes you don't. a Dual 3.2 will likely be much faster than dual 242s...but it really depends on what you're looking at.
What are you looking at doing with the system? That's the first question.
Do you want 64 bit capability?
Do you want to upgrade in the future (if you get a good Opteron board, it'll support a jump to dual core CPUs in the future...those LV Xeons won't.)?
an x2 could technically be considered a 'dualie' (I know I know, this is the SMP forum, blah blah, but let me state my point below...I love true SMP as much as the rest of you in this forum)SLiLOVER said:dang!!!! are there any good mobo's that are cheaper
I would get one but I wont have alot of money till next summer
I am not looking at x2's because i want a dualie
draconius said:an x2 could technically be considered a 'dualie' (I know I know, this is the SMP forum, blah blah, but let me state my point below...I love true SMP as much as the rest of you in this forum)
If you arent going to use an SMP OS, and run applications that run with SMP support and work with multiple threads, IMO you are pissing away your money on a dual opteron or xeon setup.
draconius said:If you arent going to use an SMP OS, and run applications that run with SMP support and work with multiple threads, IMO you are pissing away your money on a dual opteron or xeon setup.
draconius said:. If you want to game on it,
Get yourself a nice X2, with 2 gig of DDR, a couple 500 Gig hard drives, two 7800GTX's and ta da you have your nice gaming rig, for alot less than its going to cost you with dual opteron / xeon anything.
ZOMGWTFBBQ said:Could you explain this a tad more? assuming that you want SLI for games then an X2 is right up your alley, and they overclock well aswell. Most cheaper Opteron boards have a shared memory controller which makes the two CPUs more or less the same as an X2 as its got a shared controller aswell.
If your using the puter for heavy, dual threaded, memory hammering applications(rendering) then the Opterons may be more your thing. But from what i can tell from your posts your only want a dually to be able to say 'i have a dually'. The X2s are alot more your thing, cost alot less overall (specially for ram), overclock better and have a wider range of cheaper motherboards.
