Dual 2005FPW or a single 2405?
Cannibal Corpse
I am thinking about building an AMD gaming system, and had run dual monitor setup for a long time. I wish I could afford TWO of the 2405FPW ones, but I can't. However, if I get lucky and Dell offers another 40% on 2005FPW deal, I will definietely get TWO of them.
What do you think?
if you dont mide the hauge black bar down the middle of your vision, then go right ahead :rolleyes:
whats the rolling eyes for? I have dual monitors and they are about a foot apart... the space + the black bar doesn't bother me one bit.. (yes i have a 2005fpw)
its either 1920x1200 vs 1680x1050 + 1680x1050
well.. sheer numbers is favoring the dual 2005fpws... however, the 2405 does have component inputs and supports 1080i/p while the 2005 supports 720...
I guess it depends on if hi-def is a question for you..
to me, I would deffinately get the dual 2005fpws just because of the screen space your looking at... a lot more than the 2405.. but for the same price.. 2,304,000 pixels vs 3,528,000 pixels... (im kind of drunk right now so pardon the math but I think thats right)
Cannibal Corpse said:
Really? I always thought dualies are better. Hmmm... :confused:
Well it's more a matter of what you need.
Not everyone needs two monitors.
Ask yourself these questions:
Do you need more desktop real estate?
Do you freqently have more than 3 full screen applications running simultanelously? (not multiple browser windows. Things like photoshop, dreamweaver, 3dsmax, one browser, word, excel, whatever open at the same time)
Do you game more or spend more time doing other things?
In short 2 monitors are for productivity. If honestly you only type the occasional word document and browse the web and otherwise game, having the one larger monitor is probably right for you. If you spend a lot of time coding, writing, working with graphics or webdesign, using aim/icq webrowsers music while doing all of the above you probably want two monitors.
I was faced with a similar decision. I could have bought 1x 2405fpw's but I choose to go with the 2x 2005fpw's because frankly I use it.
