So I have this little mATX computer with the Biostar M7NCG400 motherboard. This motherboard has no 4 pin power socket (I think this is the "P4" connector), it only has 1 20 pin coonector for power to the motherboard.
I'm running a super small case, I bought the Fortron FSP300 power supply to replace the empty box with some wires that came with the case.
System:
Athlon XP Barton @ 1.65V
2 x 256 RAM
1 IDE HDD
1 DVD rom
9800 Pro
2 x 60 mm and 1 x 80 mm fans.
The power supply is marked:
12V1 = 8 amps = yellow wires
12V2 = 14.5 amps = yellow/black wires
The only place I see yellow/black wires is on the 4 pin connector that my motherboard does not utilize. All other connectors have yellow only wires (with no black stripe).
Question:
Since I am not using the 4 pin connector am I able to draw power from 12V2 rail?
Can I take the yellow/black out of the 4 pin and plug it into where the 2 yellow wires are on the motherboard 20 pin or should I use the yellow/ black in a dedicated molex to the 9800 Pro and run everything else off of 12V1?
This is my first dual 12V power supply so I'm a little confused about how it works. Is this computer a candidate for a single 12V power supply?
Thanks for any help.
System:
2 x 256 RAM
1 IDE HDD
1 DVD rom
9800 Pro
Question:
