Dtek FuZion Intel 775 Pro-Mount set
Ya I was looking at that. Would make my life 900x easier since I wont have to deal with sticking that damb plate down those screws as it gets caught in the threads.
Not for me, I think the stock mounting set is fine if you add a backplate from the Thermalright LGA775 bolt-thru mechanism or Scythe. I also find it much thinner than the stock and I'm worried about flexing and possibly breaking off.
So is the advantage here using a special backplate as opposed to the stock one that comes with the motherboard?
That's what I have, the thermalright backplate.
i have the scythe universal kit, but i think this will be wonders better for remounting... plus the scythe universal backplate doesnt work well with some mainboards (read:: vanilla 680i boards).
