Hey guys, i have a new Core 2 Duo setup with a Gigabyte DS3, E6300, and 2x512mb Corsair Twin2X DDR2 675.
The CPU is currently running at 2.8Ghz (400FSB) on stock voltages..dual priming makes the CPU temp go up to around 60 degrees C. Is this ok? (using stock cooler)
Also is it ok that my ram is running at 800Mhz now instead of the factory 675?
Also, everytime i reboot the computer nothing shows on the screen when restarting...i have to manually turn it off and on again. What is with this?
Btw im using my WD 200Gb HDD on the master IDE and DVD-RW on Slave on the same IDE channel as i dont yet have a SATA HDD.
Thanks.
Thanks.
