DS3 or P5B vanilla?
rubic
I'm buying an E6400 and I'm trying to decide on a motherboard. I use this computer for gaming etc. but it's also used for my home business, so stability is important. I do want to overclock but extreme overclocks are not a priority over stability. I don't want to spend more than $200 on the motherboard.
After researching for the past week the Gigabyte DS3 seems to be very popular for the 6400 and it's a great overclocker. It seems to be problematic on initial installation but once it's installed I'm not sure if stability is a problem. My other choice is to go with the ASUS P5b vanilla. Not many people have it and although ASUS is a good name I'm not sure if it's any better than the DS3.
I can wait till September before I start buying. Opinions?
DS3 has little bit better layout and more options.... It's like working with a MSI board... Have to mess around with it more to get it completely stable. Have more updated bios that might solve issues. More bios update than ASUS but this came out before the P5B...
Asus P5B=stability... Less options but enough to keep you satisfied... Questionalble layout for PCI slots... User friendly... Don't have updated bios like the deluxe yet... Doesn't support 7950 yet... Doesn't overclock to 450+ FSB like the deluxe yet... Needs a bios update...
DS3 - seems quirky at the moment, I've had a little trouble OC'ing with it. Clear CMOS jumper underneath videocard, luckily you probably won't have to use it as the normal OC failure thing works well...... (Unless you trying setting CAS to 6, like I did!! )
I'm happy with my DS3. NB runs hot, but I hear that's normal for the 965 so you'd have that problem with any board that has a passive NB heatsink.
