DS3 Help needed
ggriffiths
I recently purchased everything I needed to build myself a nice, new machine. I got a DS3 rev 3.3, E6420, as well as some other really nice parts. My problem is this:
I'm attempting to water cool this beast. I took the original HS off the northbridge and put the waterblock on there. When I boot the computer it hangs almost instantly. I'm pretty sure this is due to the northbridge overheating, and here's why: I put the stock heatsink back on, and it would run, but only for a few minutes before overheating. I'm very sure it's the northbridge because it is extremely hot to the touch. The farthest I have ever gotten was having it start an XP install. It died within 2 minutes total of boot up, and it only got this far because I left the unit off for a while. I did a very good job or removing the crappy HS, taking off the thermal paste and applying a very thin layer of Arctic Silver 5.
If I have to order a new waterblock I will, but I was wondering if there was anything you guys could suggest to try so I can ensure I don't have a bum board. Normally I check them to make sure they work prior to taking things apart, but for some reason this time I didn't (and it looks like it might bite me in the butt).
Geoff
Try some electrical tape, you might be shorting something out. If that doesn't work, I'd RMA the board. Sounds like a lemon.
Where should I try the electrical tape at?
Also, here's something else for you to chew on:
I left the machine off last night, and attempted to start it up again just now. It seemed as though it was hard locked from the start. I was not able to get into the BIOS. What I find odd is that I have been able to get into the BIOS in the past (last night) and I haven't changed anything.
My DS3 had the same issues when my backplate was shorting out the CPU socket. If you could, try the setup outside the case, put your motherboard on a cardboard box and check the backplate if you can.
