DS3 F9 BIOS
Yeah I think I read that over on XS, and it also seemed you had to loosen your memory timings from what earlier bioses had, but it's supposed to go higher. So I guess if your FSB increase isn't worth the perf. hit of looser timings, just go back to an earlier bios.
Yeah just tried 460 FSB which I used to be able to run at 4-4-4-12, and it wouldn't boot.
I didn't try #'s between but its at 3.2Ghz, 7x458, 5-5-5-15 right now.
Going to go play around with some different settings.
I have the infamous and well documented cold boot issues with both F8 and F9 so I'm sticking with F7, even if my X-Fi isn't recognized all the time ......
My rev2 DS3 came with the F7 and only recognized my X-Fi about every other boot. F9 fixed it, but every morning when I power on the board it does not POST. No video, no keyboard nothing. Power-cycling brings me back up w/out my previously set overclock. What gives? Are there any documented fixes for the cold boot issues you've mentioned? What BIOS works with X-Fi and doesn't have the cold boot issue?
