I've got them on 430 FBS. All the part are as cool as can be: one 92mm ZALMAN directed directly at the chipset, one 40mm at the memory.
It all worked fine on stock voltage on 420 FBS. The chipset got extremely hot, though.
Anyway I'm having trouble pushing forward. I even don't know if the 430 is stable enough. It wan't on a 1.4 voltage for the CPU and now it's 1.418 but haven't checked stability yet.
I have a strong feeling it's a voltage thing since the parts, as I said, are at the right temperature.
I played around with the overvoltage (both CPU and motherboard) but 440 seemed to not allow windows to run (booted OK, though... and even on 450 and 460)... any suggestion?
