DS3 Drive Issues - HELP!
Hi, Gang:
DS3 drive strangeness...
Just installed a 6300 on a new DS3 with a gig of Corsair Value Select 667 and a Seagate 250-GB perp. SATA II HD. Just looking for a solid machine with a bit of a tweak here and there -- not a huge overclock, etc.
As I always do, my first boot up is to run MEMTEST from a bootable CD. The PC has an NEC DVD-RW, and MEMTEST worked and booted fine. The F4 BIOS found all of the drives, etc, so I tried to boot my usual Hiren's utility CD to run Partition Magic 8.05 -- and the disk would not boot. Neither would Puppy Linux or Knoppix Live disks...but Acronis True Image 9.1 booted just fine... It kept asking me if I wanted to load atapicd.sys, etc...
Same thing happened with two additional drive cables and two other drives of various manufacture. I tried all kinds of settings in the BIOS -- which seems pretty goofy when it comes to setting up the various SATAII and IDE controllers... Anyway...same non-booting results...
I installed XP the tried and true way, using the install CD to partition, format, etc... As you can imagine, the XP CD booted just fine :)
So, after updating windows and the nVidia drivers,etc, I made a backup image with Acronis TI 9.1, booting from the rescue CD. The backup worked just fine, but the speed of the backup was way off. It took nearly 25 minutes to back up a base XP install that, on a typical PATA drive, takes about 7 minutes...
So, now that I have a base install backed up, I downloaded all new drivers from Gigabyte site (CONFUSING AS HELL), the new HD audio codec from Realtek (CONFUSING, TOO), and the F6 BIOS. I plan to install these and see what happens (backup on hand in case anything gets too ugly).
I ran HD tach on the Seagate drive, and it's plenty snappy...
But I'm wondering what's up with the slow backup image creation and the goofy "might boot, might not" DVD behavior.
Help?
Thanks,
--sohosources
