DS3 - Cpu and System fan Power
foxnews
I put a little fan on the NB heatsink and plug it into the System fan power connector.
my first gigabyte DS3 board seemed to control this fan speed according the temp.
Due to some other issue, I exhanged for another DS3 board. but with this new board, the fan runs a full speed all the time. it seems that the ds3 board does not control the sys fan speed. both boards control the cpu fan just fine.
Does your DS3 System fan power connector control your fan speed or not?
thanks,
You could most likely control the fan manually through Speedfan. If its connected to the mobo that should work fine.
