DS3 and CPU-Z voltages
benfinkel
Hey Guys,
I had a question about the differences I see in Voltage on my 6300 in the BIOS versus CPU-Z.
I have the Gigabyte DS3, upped to the latest BIOS revision (4E I believe?) and in BIOS is reports the "normal" voltage of my CPU at 1.32500. CPU-Z reports this voltage as 1.312. IS this just a rounding issue or is something different going on?
Thanks,
Never trust CPU-Z for voltage readout. It is wrong much more often then it is correct.
raleigh29 said:
Its called Vdroop my friend. It happens
He is right
CPU-Z voltage (in this case) is correct. Sometimes for new CPU's or chipsets it doesn't display properly. But thats right.
Vdroop =
You set voltage to X value, usually during idle its about that voltage that you set it at. Then under load it often drops about .02-.05 depending on your mobo, etc..
