Drop-in shroud?
Cbone
I'm looking for what I guess would be a drop-in shroud. I'm not sure that was what it was called, but I would swear I've seen one somewhere for sale online. You cut your case according to the outline and the shroud has a lip that overhangs and makes it look nice. So you can still have burrs and the edges all ragged and shitty with flaked paint, but you wouldn't be able to see any of that. IIRC, it came in a number of colors and sizes to hold 1, 2, or 3 120mm fans. Does anyone know where I can get something like this?
Thanks in advance.
Thanks for the links, but that wasn't it, although it did jog my memory. What I'm thinking of is more (almost exactly) like a radgrill, with sunk mounting holes for the fans, but not for the grill itself.
I think I found a better example. Like this but with an extra inch or so on each side.
