So I have this for a very, VERY short amount of time. It's. Well. Let's just say it's the most expensive box I've ever had in my lab. Take a gander at those specs!
However the damn thing refuses to stay solid at 100%. It'll hangout there for a while, then drop down to something-or-other, then eventually get back up to 100. Thought it might have been cooling, but that's not it. (Ramped the fans up to obnoxious levels, which dropped the temps big time; but no difference) Turned off all power savings. Just installed all the available updates thinking that might've helped. Told BOINC to use 128 cores via cc_config (or whatever it is). Maybe BOINC simply can't deal? Did look at the disk usage (RAID0 with two SAS12 SSDs because it's for testing and I'm lazy) and there's no usage to speak of.
Sure would be nice if this would stay solid. Of course this is more worrying than for just this little experiment. Will have to try some other tests to make damn sure this thing will peg and stay there... else we've problems!
