- Jul 17, 2006
OH_MY_FNCKING_GOD! Finally! Someone who knows what they are talking about!You can play your unprotected content wherever you want. NOTHING changes that. If you have HDCP or not. Nothing changes that. I can take unprotected MPEG or AVI files, burn to a DVD and play it in my set top that has HDCP and my display which also has it. I can plug my computer into my display which had HDCP but my video card does not and it will still play.
You can even use your PC to capture HD content via an antenna without HDCP video cards and displays.
Nothing, nowhere, will stop you from doing whatever the hell you want with your unprotected content. NOTHING. HDCP or otherwise. If you have HDCP source and display it encrypts between source and display. This is ONLY when playing it. It has not permanently been encrypted and it won't be prevented from you making a million copies of your unprotected content. It's ONLY purpose is the make sure nothing can intercept that signal between your computer and your monitor. Which doesn't even matter because nobody captures content that way. So HDCP and your unprotected content will not affect anything you care about doing. You won't even know it's there. It makes zero difference. You can play it without HDCP and you can play it with. No difference.
The ONLY thing HDCP is used for is protected HD content. Protected HD-DVD's and Blue Ray. If you want to play them you need a HDCP video card or set top box and a HDCP monitor, TV or Projector. This is NOT limited or exclusive to PC's or Vista. Everything must comply with this. And your set top has to use HDMI or DVI or the signal will be degraded. Componenet, while providing an HD signal, will still be downgraded with protected formats.
So how does this affect you? If you want to play protected content on a PC then just get HDCP compliant video card and display. Done. If you don't care about playing HD-DVD movies or Blue Ray movies on your PC then none of this matters. Your set top players and TV are already compliant so it doesn't even matter.
If you want to back up these protected discs you buy, go right ahead. The copy protection has already been cracked and programs will soon be released to making copying very easy.
