Nodoubts2k
- Aug 27, 2002
Windows stopped recognizning my two Maxtor 80gb Drives on a Raid 0 array. I know this because when i try to go into the recovery console, it says windows did not find any drives recognized. When I try to boot from the hard drive, it gives me the option to start in safe mode and normally, but neither work, I get the BSOD with "Unmountable Boot Volume". I also tried knoppix (what Im using to post now) and it still does not recognize the drives. I downloaded the Maxtor diagnostic tool and it gave me an error message that said the drives were failing, and when I called Maxtor they said that it is a Firmware failure and not a Hardware Failure, meaning that the Data is still on the drive and the firmware is just bad. Is there a way to flash the firmware on the drive? Also, is there any way to recover the data off of the drive?
