Well for those of you who are familuar with the Gigabyte MBO's, you may of heard the drivers they ship with are crap.. well so are the ones on the website.
Let me start by saying ive formated my brand new HD about 20 times (No lie). I hope thats not bad for it.
The drivers off the CD will straight up either not work, or cause windows not to boot.. awsome huh?
The ones off the internet work, but they arent as good as I thought.
The INF (Supposivly it updates your .inf files to handle PCI-E and USB better?) driver will completly lock up your system and then corrupt a USB file and not allow windows to even get to the XP loading screen. I formated so many times for that i said fuck it, workin just fine to me.
And NOW.. after I got my whole system exactly the way I wanted it, the LAN driver was working, well I use Wireless so i didnt want the icon displaying all the time that i was disconnected.
So as I was un-extracting a large .rar file, i disabled the Local Area connection, and re-enabled my wirless (I had it disabled for a bit) all at the same time, all of a sudden a few seconds later, my system locks up, completly, then it starts acting normal for about 3 seconds at a time, slowly getting worst, I restart and windows takes forever to start and does the same thing, I thought that I had overloaded my very small C: (Partition) because of the temporary files coming out of the .rar (And was interupted because of crash). After a few mins my computer was un-usable and I went to reboot again, this time windows wont even get to the Logon screen, I go to safe mode which took 10 mins to load, i could work for about 3 seconds, and then it would lock up for about 20 seconds.
I had to format.
SO, I got it back up and runnin, then i was like, ok il disable my LAN again, but this time, dont multi-task. I disable, OK.. few seconds later.. lockup.. my heart droped.
Same exact thing.
This time, I had an idea, but it was only because I KNEW that it was causing the problem, I went into my bios settings and disabled the onboard LAN, and then when i went to start windows, it asked me if I wanted to start with LAST GOOD CONFIGURATION, so i selected that, (Just in case) and she came right up.
I am so F*****G pissed, this is my first build and i have had more problems then i know what to do with. Now I dont have onboard lan, I would like to get it to where its disconnected all the time (Because it does work) but im not sure how I could get windows to Enable it. Im not sure if thats included in the Good Config I loaded, or mabye if I re-install the driver, it would enable it, all i know is im scared as shit to re-enable it in my bios in fear of having to format again, i dont loose my files (Because of partition) but ive done it so many times i memorized stuff.. and you know theres somthing wrong with that..
Well.. just thought id let off some steam.
I had to format.
Same exact thing.
