Drivers for a VERY old MOBO
bigdaddy
[H]Lite
Installed Win2000 on it which instAlled drivers for all the devices.
What I wish to know is should I install newer drivers on it, and where would I get them?
The board is:
EP-61BXA-M EPOX Slot 1 Intel 440BX
If all the hardware is working, it's not really necessary to update any drivers. With that old of a board and Windows 2000, it's unlikely you'll even find any newer than whats included with Windows.
yeah ..if it ain't broke ..then dont try and fix it..
being that old, your are obviously not looken to get any high 3dmark scores with that setup .. you are more then likely just wanting a stable old rig that just works ...so ..if it works ...
..well ..you know :)
the 440BX did not need special chipset drivers...
windows 2000 does everything automatically without issue...
The chipset was so good, standard, and complete that no drivers needed to be released.
