Driver versions?
x1600c
As of late, which version of the forceware driver gives the best framerate with the 6800?
I have been using the 71.xx and they seem to be working just fine for me.
Issues Resolved in Version 67.66
This following are changes made and issues resolved since driver version 67.03:
• SLI cards: Half Life 2 performance drops on ʺcanalsʺ demo with SLI
enabled.
• GeForce 6800 Ultra, SLI: No performance difference with the game
Lock On Modern Air Combat when SLI mode is enabled.
• GeForce 6800: Incorrect fog for underwater objects in Half Life 2.
• SLI cards: Shadows flicker with Source engine games like Half-Life 2
and Counterr-Strike when SLI mode is enabled.
• Windows XP Media Center Edition, GeForce 6600: Graphical
distortion appears intermittently when cycling through the Media
Center menus.
• Windows XP Media Center Edition, GeForce 6600: From HDTV
component-out, changing the resolution from 1080i or 720p to 480p
results in 480i being set instead.
• GeForce 6600 GT: NVIDIA Color Correction does not work when
playing video using VMR.
• GeForce 6800 LE, PCI-Express: With an HDTV as the secondary
display in Clone mode, the TV loses sync when changing the
resolution to 1080i with Keep Native HDTV resolution selected.
• Windows Media Center Edition, GeForce PCX 5300: When using
HDTV over DVI, 1080i mode does not sync correctly in native and
underscan modes.
• GeForce2, GeForce4 MX, Windows XP: City of Heroes crashes to the
desktop intermittently.
awesome, i was experiencing that first problem noted above about decreased performance in HL2 canals with SLI enabled
