Driver Store Explorer (RAPR)
bigdogchris
I just wanted to share some software I've been using for several years that no one seems to talk about.
It's basically a GUI utility to see which drivers were installed on your Windows driver store at any point in the past, shows how much space they are using, and what versions are available if you rollback.
A couple other useful features are ability to select old unused drivers to delete and exporting all of your currently installed drivers if you are reinstalling Windows.
Check it out here https://github.com/lostindark/DriverStoreExplorer.
sounds like it could be handy. i usually just flush mine through disk cleanup though...
