Ok my little brothers machine has been running fine for a long time up until a few days ago, it's probably something he did but I can't seem to figure it out. His system:
Athlon XP 1900+
ECS K7S5A v3.1(onboard audio & lan)
512mb PC2100 ddr memory
Creative Labs Soundblaster Live! CT4760 sound card
GeForce3 video card
Ok anyway the issue is only with a sound card, he booted up yesterday and no sound, I go to reinstall soundcard drivers and it copies all files over and then skips over and gives the error "The data is invalid." I tried removing the soundblaster drivers then removing the card and enabling onboard audio, downloaded it's drivers and install them and it gives the same error. I tried putting in a 56k modem with a built on sound card, it installs the modem fine but when it goes to install the audio drivers for the card it gives the same error. It seems to be only sound card drivers that cause this and it labels the device MEDIA in the device manager when it gets the error. Everything else functions perfectly except for the sound card.
I have researched the error and most people have fixed it by changing permissions in the registry for the HKLM\System\CurrentControlSet\Enum\PCI and allowing the user account full control, but no such luck for me.
Any suggestions?
Athlon XP 1900+
GeForce3 video card
Any suggestions?
