Driver Cleaner.......uh oh
Black Label
i was using driver cleaner to clean out my old ati drivers and i accidently cleaned out the 3dfx drivers. it deleted a bunch of stuff that said voodoo and banhee.
is this bad?
Not bad unless you are using a 3dFX card. In that case, just reinstall the glide drivers ;)
my card is a powercolor 9600xt, do i need those drivers? where do i get them?
You dont need glide drivers unless you are using a 3DFX card. 3DFX made the Voodoo 1-5 cards, and went out of business back in 98 or 99. If you are using a ATI card you have no need for the 3DFX drivers. You're good to go. ;)
ok thx man
